mickey7
Sep 23, 2018Aspirant
How do I use the Netgear Genie app -Step by Step
So Folks, HOW do I use the Genie app? No Clue. I have a Chromebook , so I can use the genie on it. Not compatible. I want to know how to change channel, if needed. etc. Please Help someone. I am a Ne...
- Sep 25, 2018
The latest firmware for this router comes with "Added support for SHA256 certificates in lieu of MD5 for OpenVPN":
R6700 Firmware Version 1.0.1.48 | Answer | NETGEAR Support
for the V2 variant:
R6700v2 Firmware Version 1.2.0.24 | Answer | NETGEAR Support
"Supports SHA256 certificates instead of MD5 for OpenVPN".
michaelkenward
Sep 24, 2018Guru - Experienced User
mickey7 wrote:
How do I use this APP??
Hard to know without any clue as to what you want to achieve.
- Turn on tablet.
- Install app
- Run app
- Connect to wifi from R6700 (see label for SSID and password)
- Login to manage
- Do whatever it is that you want to do.
There is a manual for the genie Mobile App somewhere at the end of this link:
>>>> genie Landing Page <<<<
mickey7
Sep 24, 2018Aspirant
Thank you for the link to the menu to the app. This looks like this will give me the answers I am looking for. On Windows I was able to figure the info out, kind of. Chromebook is Not compatible with the regular login page. The last time I used this app( about 6-8 months ago) I just about Completely F#@cked up my router and wifi settings. I did NOT want to do that again. Thanks again. Harold.
- schumakuSep 24, 2018Guru - Experienced User
Dear Harold,
A Chromebook does run the very same Chrome browser as it's on e.g. Windows. Unclear ot me why you repeat mantra-like that the Chromebook should not be compatible with the "regular" (I'm reading the Web based Genie) login. As the Chrome browser has a very high market share, any related problems would show up here in the Netgear Community.
What problems do you have on working the R6700 Web Genie from a Chromebook resp Chrome Browser?
Chromebook model, ChromeOS Version?
R6700, R6700v2, or R6700v3?
R7600[-|v1|v2] Firmware version?
Many modern Chromebooks are supporting the installation and operation of Android Apps in the Stable Channel -> Chrome OS Systems Supporting Android Apps This would allow the installation and running Netgear Genie App (and in case it's a R6700v2 or R6700v3 also the Nighthawk App) right away on select Chromebooks, too.
Should this problem remain, and permitting some useful information can be provided, I'm happy to push this onto some Netgear desks.Regards,
-Kurt
PS. Working for years on the road with an elderly Acer CB3-111 (no Android support yet), currently on Chrome OS v70 beta (64-bit).- mickey7Sep 24, 2018Aspirant
OK, First off I have Version 2 of my R6700 Router. I was also very disappointed that this version is Not compatible for open source firmware, although I hear there is a possiblity of Tomato firmware.
Secondly, I Apologize for my seemingly harsh tone earlier. I have just found out that I Can reach my Netgear Genie page for my router. I simply wanted to check to see if I could find a different channel that might give me a faster signal. I Think I can sort out these things on my own.
One last question, would you folks recommend my buying an extended warranty for any further problems I may have? Or.....will the Good folks here at this forum/ community be able to give me a hand with any subsequent issues? Thanks again so much . Harold.
- schumakuSep 25, 2018Guru - Experienced User
Wireless is always a variable target. Start providing more details about the systems where you expect a faster signal. As queried above already. Then about the environment where you want more performance.
What levels of warranty and support does NETGEAR ProSupport for Home offer? Different plans are available. While it's good to have an extended hardware warranty, it depends on your expectations when it comes to support.
