mickey7
Sep 23, 2018Aspirant
How do I use the Netgear Genie app -Step by Step
So Folks, HOW do I use the Genie app? No Clue. I have a Chromebook , so I can use the genie on it. Not compatible. I want to know how to change channel, if needed. etc. Please Help someone. I am a Ne...
- Sep 25, 2018
The latest firmware for this router comes with "Added support for SHA256 certificates in lieu of MD5 for OpenVPN":
R6700 Firmware Version 1.0.1.48 | Answer | NETGEAR Support
for the V2 variant:
R6700v2 Firmware Version 1.2.0.24 | Answer | NETGEAR Support
"Supports SHA256 certificates instead of MD5 for OpenVPN".
schumaku
Sep 25, 2018Guru - Experienced User
I'm with michaelkenward for the similar reasons - hardware yes, for firmware/software ... not in this device class.
"my VPN" whatever you want to do - again as michaelkenward mentioned, Netgear has updated the VPN server so it is possible to establish a "calling-home" OpenVPN connection again.
While "Open Source" does sound good, it's even harder to get "just in time" support.
mickey7
Sep 25, 2018Aspirant
As you folks may already to be able to tell, I am Really Not very tech savy. I am mostly a plug it in , setup a couple of things and expect the item( in this case a router) to do whatever is expected it to do. From what I've been able to tell from different posts from this community, this open source update "seems" very complicated and not stable. I looks like if I want to get a router and use open source firmware, I better off getting a different router, like the AC 1900 Nighthawk. Your thoughts? Thanks again, so much. Harold.
- michaelkenwardSep 26, 2018Guru - Experienced UserI'm still trying to understand what the challenge is here.What started off as a question about the Netgear genie, which is not really your problem, has now morphed into something very different.
Have we narrowed it down to getting a VPN to work?
If so, what VPN is this and have you talked to the people who supply it?
That works in most cases, but it depends on the rest of the network. In particular, the modem in front of the router and what you want to do that is out of the ordinary.
Both get in the way of the simple "plug and pray" approach.
- mickey7Sep 26, 2018Aspirant
Dear My Apologies Again, for going against the rules of this community. I thought as long as I was having a chat with some experienced people I could ask you nice folks whatever I needed to know. I see now thatif I change topics than I need to change my base question. As I do more research for a new or different router I will come back and start a New question. I appreciate all of your help with so many different things. My Thanks, Michael and everyone that has helped.
You have every right to change horses in mid stream. But it helps if we all know what the current issue is.
By all means talk about VPNs here, rather then the Apps, but when you do start on a new quest it helps to provide any extra information that can shorten the journey.
Another approach is to start a new conversation, in the right place of course, about your latest concern. Give it a more meaningful title and you may draw in people who know more about the topic and who may not have seen this discussion which, to them, has a misleading subject. People who know about VPNs may be ignorant on Apps, and vice versa.
