CastleAlcoa
Mar 29, 2016Aspirant
How do I use the Nighthawk X4S AC2600 R7800 without a modem? Does it provide better performance?
Hello everyone, I have recently purchased this router and keep reading online and hearing about how this router acts as both a router and modem. I'm guessing the initial setup of this router into yo...
- Mar 30, 2016
That is D7800 not R7800... D7800 is modem/router but R7800 is just a plain router.
The product category of being AC2600 or AC3000 etc is the total wireless speed (2.4 +5Ghz band) your device is capable of but it doesnt mean there is just 1 model in that category.AC1750 example has 3 models (R6700, R6300 or R6400).
To know more about your model you may check the User Manual or the Datasheet on what the specs and features.
storm1985
Mar 29, 2016Prodigy
No you can't set R7800 as your modem. There's no coax port on this router. This is just a regular router!
CastleAlcoa
Thank you for a prompt reply, however what are all these articles and youtube videos saying that; "The appeal of the Nighthawk X4S over the X4, for example, is that it features a DSL modem. It isn't only the router part."
- CastleAlcoaMar 29, 2016Aspirant
Also this:
"VDSL Modem Router with Nighthawk® X4S AC2600 WiFi VDSL/ADSL Modem Router (D7800) (www.netgear.com/D7800). With a dual-core 1.4GHz processor and built-in DSL modem, it’s the first DSL modem router on the market to support the latest Wave 2 WiFi technology with Quad-Stream on both bands as well as Multi-User MIMO-capability"
you can read a lot about it here:
- storm1985Mar 30, 2016Prodigy
The model numbers will help you identify what your device is for.
D - for DSL modem gateways ex. D7000
C - for Cable modem gateways ex. C7000
R - for Routers ex. R7000
