jcollum
Sep 07, 2025Aspirant
how do I whitelist IP addresses on the R7500v2?
I'm having issues using a plugin for Claude called Claude Code. I'm getting ECONNRESET. In my router logs I see [DoS Attack: ACK Scan] from source: 44.215.74.30, port 443 [DoS Attack: ACK Scan] ...
- Sep 19, 2025
It looks like my ISP (Centurylink) was blocking Claude Code. I used a VPN and now it works.
jcollum
> probably a low level, almost clerical task to go through the entire list of Netgear products and ensure that every one of them appears in the "tag database".
the kind of thing an intern should do -- I'm sure they have a database that has a list of product families
Sep 08, 2025Guru - Experienced User
Most likely not added due to the this model router and others are EoL.
