jcollum
Sep 07, 2025Aspirant
how do I whitelist IP addresses on the R7500v2?
I'm having issues using a plugin for Claude called Claude Code. I'm getting ECONNRESET. In my router logs I see [DoS Attack: ACK Scan] from source: 44.215.74.30, port 443 [DoS Attack: ACK Scan] ...
- Sep 19, 2025
It looks like my ISP (Centurylink) was blocking Claude Code. I used a VPN and now it works.
CrimpOn
Sep 07, 2025Guru - Experienced User
Netgear consumer routers do not provide a feature to whitelist IP addresses. The default condition is to not accept connections from the internet unless the user has specifically set up Port Forwarding. When that is done, a connection attempt is passed through the router to the IP address specified in the Port Forwarding definition.
Those entries in the log are from a process that Netgear has running to observe connection attempts. When the process observes a sequence of attempts that fit a known pattern, an entry is made in the log. These entries say that three IP addresses made enough attempts to connect to the router web server using https (port 443) that they could be considered a Denial of Service (DoS) attack.
Unless Claude Code includes a web server, there is no obvious relationship between these log messages and the ECONNRESET error message. (Internet search turns up LOTS of posts about this error message, especially for the MacOS platform.) Whitelisting three random IP addresses is not the solution.
jcollum wrote:Weird that there's no tag for R7500.
more like annoying. probably a low level, almost clerical task to go through the entire list of Netgear products and ensure that every one of them appears in the "tag database".
jcollum
Sep 18, 2025Aspirant
I talked to Anthropic (who owns those IPs) and they said
> When a user's applications make requests to Anthropic's API, they initiate an outbound connection to our servers. The IP addresses they see (44.215.74.30, 52.39.32.173, 35.186.224.46) are our response servers sending data back to them - this is standard client-server communication.
Which makes sense. So why would Netgear see that traffic as a DOS Attack in the logs?
- jcollumSep 18, 2025Aspirant
I can't edit that. They also said:
>Anthropic never initiates inbound connections to customer networks. All communication flows outbound from their network to our endpoints, with responses coming back through the same established connection.
>Your router's DoS protection is incorrectly flagging these legitimate API responses as threats.
- FURRYe38Sep 18, 2025Guru - Experienced User
Something that NG routers may not be able to distingish from. Logging is probably genralized and not specific to seperate what maybe actual attack or something other than and won't be changable.
