jcollum
Sep 07, 2025Aspirant
how do I whitelist IP addresses on the R7500v2?
I'm having issues using a plugin for Claude called Claude Code. I'm getting ECONNRESET. In my router logs I see [DoS Attack: ACK Scan] from source: 44.215.74.30, port 443 [DoS Attack: ACK Scan] ...
- Sep 19, 2025
It looks like my ISP (Centurylink) was blocking Claude Code. I used a VPN and now it works.
jcollum
Sep 19, 2025Aspirant
jcollum
You might be thinking "call your ISP and get them to fix that"... the tech support with this ISP is so laughably bad it would take me half an hour to find someone who can even understand the issue.
