KevinAZ's avatar
KevinAZ
How do Install my VPN on Netgear router?
Hello,
My model was not listed in the drop down list. I have the Nighthawk AX6 AX4300 router and am trying to install my IPvanish I can't find any directions anywhere. Any help would be greatly appreciated.
Thanks,
Kevin
  • plemans's avatar
    Did you check IPVanish's site?
    you install it on your individual device (phone/computer/etc).
    Not on your router.
  • michaelkenward's avatar
    michaelkenward
    KevinAZ wrote:
    My model was not listed in the drop down list. I have the Nighthawk AX6 AX4300 router...
    There's a label on the thing. That would probably be the RAX45 or RAX50.
    It sure ain't the A7000|Nighthawk AC1900 WiFi USB Adapter in your footer.
  • I apologize, my main router I'm trying to setup IPvanish VPN on is C7800|Nighthawk X4S-AC3200. Does anyone know if this is possible?
    Thanks
    I also have the RAX45 which I guess runs the Armor VPN.
    • plemans's avatar
      No you can't install IPvanish on the C7800 or the RAX45.
      IPvanish has a list of routers on their site they support.
      https://www.ipvanish.com/vpn-setup/routers/#routers-setup
      Neither of those routers is on there. IPvanish is 3rd party firmware. You'd have to ask them if they'll ever support the RAX devices.
      The C7800 is a modem/router combo device and the firmware is locked by the ISP.
