BeWill57
Jan 31, 2022Aspirant
How many devices can R7960P support?
My R7960P connects to the internet, but I have lots of drops of my internet connection, different devices (iPad, Intel Laptop). Distance from router does not matter, three feet or 50 feet with wall between device and router. I have more devices now than I did before I started have this issue.
How many devices in total do you have connected all at once?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What channels are you using?
Any Wifi Neighbors near by? If so, how many?- BeWill57Aspirant
Hi FURRYe38
Number of devices 24 - 34 devices.
Firmware Version V1.4.2.84_1.3.42
Showing 6 Neighbors or available wireless networks, broadcasting SSID
Spectrum is the current provider, but I had the same problem with AT&T
Modem Manufacturer Technicolor Model E31T2V1Channels2.4GHz set to auto5.1GHZ set to 445.2GHZ set to 153- FURRYe38Guru - Experienced User
You should be fine...
How many clients can you connect wirelessly to a NETGEAR router? | Answer | NETGEAR Support
So that is unlikely to be the issue.
