jetman024's avatar
jetman024
Follower
Nov 16, 2020
How to check prior Logs for Netgear Router R7800
Every couple hours our Nighthawlk router loses wifi. All the lights turn off for a second then turn orange before regaining signal. Our modem does not lose signal and ISP confirms service was not lost. When I check the log it only shows data from when it reconnects. Is there a way to check the log prior to losing service? Anyone else have this issue?
Thanks
    • JayboH's avatar
      JayboH
      Apprentice
      Ok so awhile back what I did was factory reset by holding a toothpick in the reset button for half a minute just to be extra sure.  When it asks you to update to the latest firmware (.76) I said yes.
      Now here's the kicker:  do NOT restore your saved settings.  Put them in manually one by one.
      I haven't had any issues at all now.  You can see my past posts that .76 was giving me lots of problems until I did this (I discussed it in several threads, not just this one.)
