Luauprince
Mar 19, 2018Aspirant
How to connect WD My Cloud 4TB to R9000 as my Plex Media Server
Hello all, I hoping someone can help me. I am trying to connect my WD MY Cloud 4TB external hard drive to my R9000 router as my plex media server but everytime I type in my WD MY Cloud 4TB credentia...
- Mar 20, 2018
There might be other potential issues like a SMB protocol not matching, potential issues again with parsing username or password when using "special" characters (beyond of 0..9, a..z, A..Z). All these might lead to the similar misleading error message.
Repeating and reposting attachments does not help.
schumaku
Mar 20, 2018Guru - Experienced User
schumaku
Current v1.0.3.10 firmware in place by the way?
- LuauprinceMar 20, 2018Aspirant
Yes, I have current firmware.
I didn't mean to repeat or repost, I only did it because I didnt see my original attahcment go through
- schumakuMar 20, 2018Guru - Experienced User
Ah, no worries.
Have played with a similar shared folder name, and applied some restrictions in the SMB protocol supported here on a SAMBA server. The R9000 (1.0.3.10) does nicely mount using SMB 1.0 ...
Spoilerroot@R9000:/# mount
//192.168.1.99/Plex\040Media on /tmp/mnt/NAS1 type cifs (rw,relatime,vers=1.0,sec=ntlm,cache=strict,username=test,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.1.99,file_mode=0755,dir_mode=0755,nounix,serverino,rsize=61440,wsize=65536,actimeo=1)...as well as SMB 2.1 if SMB 1.0 is not available.
...//192.168.1.99/Plex\040Media on /tmp/mnt/NAS1 type cifs (rw,relatime,vers=2.1,sec=ntlmssp,cache=strict,username=ks,domain=TVS-473,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.1.99,file_mode=0755,dir_mode=0755,nounix,serverino,rsize=65536,wsize=65536,actimeo=1)
Do you have some restrictions in place on your WD NAS ie. for the min and/or max SMB version supported?
I've tried to gain access to the output or error caused by the mount attempt, but discovered the debug-log.zip is always corrupted on the firmware (pre-release) in place on my R9000 ... bugger.
PS. The attachment is part of the first post already, on the right tab:
So it was my password, it was to complex. After I simplified my password I was able to connect to my NAS. Now I'll see how solid this connection will be. Thanks a bunch schumaku
Would you mind to share some details of the password complexity in place - length, special characters, special leading or trailng chars (ie. spaces, \, ", ', ... you get the idea - I would love to push Netgear to remove the limitations you hit.
