luguanyu's avatar
luguanyu
how to disable ipv6 firewall
my isp provide ipv6 connection, also I complete ipv6 configure and get success message using ipv6test.com
I can connect my pc using my tablet with rd client via ipv6 address, but can not login my pc using 4G mobile net.   Is the router drop the ipv6 syn from Internet to lan pc? So how i can disable the 'firewall'?
here is my trying.
   - in Advanced -> IPV6 -> IPV6 Filtering -> Choose open
  - NAT Filtering -> Open
 seems not work.
These works fine when i use another band router.
  • Yoou cannot easily disable the IPv6 firewall, at least not throough the GUI
    • luguanyu's avatar
      luguanyu
      Thank you.  Is all the netgear routers can not do this via web gui?
      I think it's an important feature...
