namlah1936
Nov 19, 2020Aspirant
HOW TO DISABLE THE 5 G BUT KEEPING THE 2.4G ACTIVE ONLY ON A AC 1750 SMART WIFI ROUTER
HOW CAN I DISABLE THE 5G ON A AC1750 SMART WIFI ROUTER AND KEEP THE 2.4G ACTIVE
A couple things.
1. Caps lock. It helps for reading these.
2. What router do you have? AC1750 is a speed, not a model.
3. why do you want to disabled 5ghz? Its much faster than 2.4ghz. Maybe explaining why you're wanting to do something will help figure out the issue.
here's a general guide:
https://kb.netgear.com/24101/How-do-I-enable-or-disable-the-wireless-radios-on-my-Nighthawk-router
or go to netgear.com/support/ type in the model number. It'll take you to the manual to go over your specific manual.
- namlah1936Aspirant
I have a sensi wifi thermostat that requires 2.4v for it to work properly
You don't have to shut off 5ghz for it work. You simply have to have make sure the phone is connected to the 2.4ghz during setup of the thermostat.
You shouldn't need to but its lazy coding on the developers side that cause you to need to do so.
