hniz's avatar
hniz
How to do NAT on internal subnets
Good Evening,    I puchased this router to replace my Cisco RV320 router after upgrading to Comcasts 1Gbps service. The gentleman at Frys said that the router can NAT subnets that are routed thru m...
  • TheEther's avatar
    Aug 11, 2017
    Stock firmware can only NAT its own subnet.  It will not NAT other subnets behind another router or L3 switch.
