Valkyrie99
Jan 10, 2022Tutor
How to downgrade R7900P to 1.4.1.68
I've seen posts about browser loading issues after upgrading firmware to 1.4.2.84, and the solution is suggested to downgrade to the previous version 1.4.1.68. Where can I get that version? I'm not finding it available in the Netgear downloads.
https://www.netgear.com/support/product/R7900P.aspx#download
Besure to select the Prior Versions.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Awesome, that was exactly what I needed. I performed the "downgrade" and the problem went away. Now hopefully Netgear will fix the problem and provide a new firmware update!
Much obliged!
- sloanishAspirant
I had intermittent errors after upgrading to R7900P-V1.4.2.84_1.3.42.zip
Happened on wired and wireless
Had to downgrade back to R7900P-V1.4.1.68_1.3.28.zip
Foloowing this to see if there is anymore progress
Error was as follows
Hmmm... can't reach this page
Check if there is a typo in www.example.com
DNS_PROBE_FINISHED_NXDOMAIN
