kn4hh's avatar
kn4hh
Tutor
Nov 29, 2020
How to give one of my PC's on the network a static ip address so it will not change
I am using a AC-1750 R6400 router.  I have several PC's connected to my home network.  I need one of my PC's to have an ip address that will not change whenever the router is booted.  I remotely access a server on the PC through port 1880.  I need to have that particular PC always available at the same ip address.
I would appreciate asssitance on how to configure the router to accomplish this.
Bob W.
  • > Model: R6400|AC1750 Smart WiFi Router
       Is that accurate?  R6400[v1] or R6400v2?  Look for "Model" on the
    product label.  Firmware version?
    > will not change
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual.  Read.  Look for a
    topic like "Manage Reserves [sic] LAN IP Addresses".  Further reading
    might not hurt, either.
       Terminology: A "static" address is configured on the device itself.
    What you configure on a (DHCP server on a) router is a reserved dynamic
    address, not a static address. Either one should fix the address of a
    device, but some implications are different, so it helps to know which
    you mean.
    • kn4hh's avatar
      kn4hh
      Tutor
      Thanks for you assistance.  Problem solved.
      Bob W.
