rst303
Feb 15, 2017Aspirant
how to install openvpn to run from a router
I am trying to set up a openVPN to run directly from my router, so I can use a single device login, and then connect multiple phones etcs to use that VPN. Any help appreciated thanks
- Apr 12, 2017
Hi Ranchor2,
The OpenVPN will not work if the R7000 is connected to another router. The R7000 should have a public IP on order for the OpenVPN to work.
odded
Mar 14, 2017Aspirant
Use this website to assist you https://support.opendns.com/hc/en-us/articles/228007927-Netgear-Genie-Web-Interface-Device-Configuration
