rst303
Feb 15, 2017Aspirant
how to install openvpn to run from a router
I am trying to set up a openVPN to run directly from my router, so I can use a single device login, and then connect multiple phones etcs to use that VPN. Any help appreciated thanks
- Apr 12, 2017
Hi Ranchor2,
The OpenVPN will not work if the R7000 is connected to another router. The R7000 should have a public IP on order for the OpenVPN to work.
Ranchor2
Apr 06, 2017Aspirant
I'm also interested in setting up the nighthawk as the VPN router and plan to get the Nighthawk 1900. I have ATT Uverse service, so will I be using 2 routers, the ATT NVG599 and the Nighthawk 1900. Are there step by step procedures netgear publishes for starters for cable customers?
JamesGL
Apr 12, 2017NETGEAR Employee Retired
Hi Ranchor2,
- JamesGLApr 16, 2017NETGEAR Employee Retired
Hi Ranchor2,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
