rst303
Feb 15, 2017Aspirant
how to install openvpn to run from a router
I am trying to set up a openVPN to run directly from my router, so I can use a single device login, and then connect multiple phones etcs to use that VPN. Any help appreciated thanks
- Apr 12, 2017
Hi Ranchor2,
The OpenVPN will not work if the R7000 is connected to another router. The R7000 should have a public IP on order for the OpenVPN to work.
JamesGL
Apr 12, 2017NETGEAR Employee Retired
Hi Ranchor2,
JamesGL
Apr 16, 2017NETGEAR Employee Retired
Hi Ranchor2,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
