JCH0321's avatar
JCH0321
Follower
May 30, 2017
How to log into your router and not the cable modem, both uses NETGEAR genie
I have a NETGEAR cable modem (AC1900- C7000). Just bought NETGEAR wireless router NIGHTHAWK X8 (AC5300).
Every time I try to log into the router using the instructions (routerlogin.net) it takes me to the cable modem (AC1900) and not the router where I need to upadate the firmware.
How can I log into the router and modem separate? using routerlogin.net it always takes me to the cable modem???
I'm confused, Appreciate any help
  • Hi JCH0321,
    Access it via the IP address of R8500. Check your computer's default gateway and use that address.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi JCH0321,
    • JamesGL's avatar
      JamesGL
      Hi JCH0321,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
