Alierace's avatar
Alierace
How to permanently remove "Circle" pop-up
FW V1.0.11.100_10.2.100 has "Circle" pop-up that has no option to hide it. Every time you login into router, it pops up. Is there a way to disable it permanently?
  • I was a browser cookie issue. Can MOD delete my post as i cannot find a way to do it myslef.
    • jlwilkinson's avatar
      jlwilkinson
      If it was a "browser cookie issue" please define HOW you resolved it.  I get this on different browsers on different machines.
      • Alierace's avatar
        Alierace
        I cleared browsing history  "all time" not just session and after login to router, closed the pop-up. logout without closing, login back and repeat couple times till no more popups. After that it somehow remembered and stayed put :), maybe it has an internal pop-up count.. idk.
