siamak
May 03, 2023Aspirant
How to reset e-mail and password
I just bought the subject product from a friend. He does not remember the e-mail address and the password on the router. How do I reset these? When I connect to the router, it does not allow me to set it up again. It asks for e-mail and password and offers no other option.
Is there a way to reset the router to allow me to set it up again?
Thanks for your help.
Not much to go on.
What NG product model are you referring too?Has a factory reset and setup from scratch been performed? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-routerRecommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Not much to go on.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router - siamakAspirantThank for the information. One of the URLs that you sent, took me to a page that showed me how to do it. It is done!
Thank you very much for your help.- FURRYe38Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
