melobyrro
Feb 13, 2016Follower
How to setup readyshares in kodi?
Hi, this is my setup, r7500 with usb storage connected to it, on the same network I have an android set top box runnning kodi, I cant figure out how to add that ready share drive to kodi, http connects but opening it inside kodi no files appear,
on my pc know how to connect thru \\readyshare, but how to access \\readyshare from kodi? is \\readyshare nfs, ftp, smb?
It should go something like this:
Videos > files > add videos > browse > Windows network (smb) > workgroup > Readyshare > T Drive (in my case) > OK and then you can name the drive and set your scrapers info. After this you should be able to go back to Files and see the Readyshare drive there. That is what I did in any case.
- storm1985Prodigy
it should work with FTP or SMB
- z06galAspirant
