kryptonix
Sep 26, 2018Guide
How to unbrick the Nighthawk R7000 using OS X and TFTP
Hi,
After spending a night on unbricking my R7000 and how I struggled to work with all the manuals out there but none of them actually worked. I thought I should share what actually worked for ...
- Sep 27, 2021
HOLY COW IT WORKED!!!
nmrpflash worked!!! Switching to a Static IP address and turning my Wifi off did the trick!!
Also, recommend using -vvv to double check when it works. Took me two tries to nail the timing because the router has to finish restarting for the packet transfer to begin before the command times out.
myersw
Sep 01, 2019Master
If you are following directions and using windows tftp you need to be in the directory where the firmware is stored. Otherwise the tftp client cannot find it. So make sure directory you are in has the file.
Firmwarefailure
Sep 01, 2019Tutor
I am using a Mac - not Windows. Am I missing something? I checked for the file as instructed by checking the desktop files in the terminal app.
