kryptonix
Sep 26, 2018Guide
How to unbrick the Nighthawk R7000 using OS X and TFTP
Hi,
After spending a night on unbricking my R7000 and how I struggled to work with all the manuals out there but none of them actually worked. I thought I should share what actually worked for ...
- Sep 27, 2021
HOLY COW IT WORKED!!!
nmrpflash worked!!! Switching to a Static IP address and turning my Wifi off did the trick!!
Also, recommend using -vvv to double check when it works. Took me two tries to nail the timing because the router has to finish restarting for the packet transfer to begin before the command times out.
Firmwarefailure
Sep 02, 2019Tutor
I want to thank all for their help, support and advice. I was finally able to upload the new firmware. It was my fault that I had so much trouble doing so. Stupid rookie non tech savvy mistake. I copied the whole file to my desktop versus just the exe green file. Once I found the errors of my ways, the firmware loaded flawlessly and I'm up and running.
Again, thanks to all.
myersw
Sep 02, 2019Master
YAH! Glad you finally figured things out and are up and running. Be sure, if you have not already, to turn auto update off. Since your MAC connects to the router via Ethernet you can do manual updates of the firmware which is way safer.
