kryptonix
Sep 26, 2018Guide
How to unbrick the Nighthawk R7000 using OS X and TFTP
Hi,
After spending a night on unbricking my R7000 and how I struggled to work with all the manuals out there but none of them actually worked. I thought I should share what actually worked for ...
- Sep 27, 2021
HOLY COW IT WORKED!!!
nmrpflash worked!!! Switching to a Static IP address and turning my Wifi off did the trick!!
Also, recommend using -vvv to double check when it works. Took me two tries to nail the timing because the router has to finish restarting for the packet transfer to begin before the command times out.
moonweasel
Dec 19, 2018Aspirant
This post was helpful in my quest, since like you mentioned, the TFTP commands listed in all the Windows unbricking guides don't work in macOS Terminal.
For me the method still does not work, because in Step 3, ping returns mostly
Request timeout for icmp_seq xx
without the
ttl=100
Naive
Apr 17, 2020Aspirant
Moonweasel , I have the same error. Did you figure out how to fix this?
- antinodeApr 17, 2020Guru
> Moonweasel , I have the same error. [...]
"same" as _what_?
> [...] Did you figure out how to fix this?
"this"? _What_?
Rather than starting your own thread for your own problem, you've
joined a many-months-old thread with thirty-odd postings. Pronouns and
other vague references are approximately useless here.- NaiveApr 18, 2020AspirantThis is my question/reference, it’s the second reply in this thread:
without the
ttl=100>>
—- Did you get a solution to the above?
