kryptonix
Sep 26, 2018Guide
How to unbrick the Nighthawk R7000 using OS X and TFTP
Hi,
After spending a night on unbricking my R7000 and how I struggled to work with all the manuals out there but none of them actually worked. I thought I should share what actually worked for ...
- Sep 27, 2021
HOLY COW IT WORKED!!!
nmrpflash worked!!! Switching to a Static IP address and turning my Wifi off did the trick!!
Also, recommend using -vvv to double check when it works. Took me two tries to nail the timing because the router has to finish restarting for the packet transfer to begin before the command times out.
Fiddlededee
Feb 20, 2020Initiate
kryptonix I signed up for this community just so I could thank you for saving my evening sir. The binary instruction saved it all. Thank you.
kryptonix
Apr 17, 2020Guide
Glad to help out, that’s where this community is for;)
