kryptonix
Sep 26, 2018Guide
How to unbrick the Nighthawk R7000 using OS X and TFTP
Hi,
After spending a night on unbricking my R7000 and how I struggled to work with all the manuals out there but none of them actually worked. I thought I should share what actually worked for ...
- Sep 27, 2021
HOLY COW IT WORKED!!!
nmrpflash worked!!! Switching to a Static IP address and turning my Wifi off did the trick!!
Also, recommend using -vvv to double check when it works. Took me two tries to nail the timing because the router has to finish restarting for the packet transfer to begin before the command times out.
Hossan
May 10, 2020Aspirant
Hi kryptonix thanks for your step by step instructions, but that did not work for my device, my Macbook is late 2011 and has an ethernet port so i can connect the router throuh the cable , however i have tried the steps thrugh my terminal which showing ttl-64 (not 100) like urs, when i have typed the command tftp>EX6120-V1.0.0.40_1.0.30.chk after a while it replied Request timed out.what elase can i do?
thanks
