kryptonix
Sep 26, 2018Guide
How to unbrick the Nighthawk R7000 using OS X and TFTP
Hi,
After spending a night on unbricking my R7000 and how I struggled to work with all the manuals out there but none of them actually worked. I thought I should share what actually worked for ...
- Sep 27, 2021
HOLY COW IT WORKED!!!
nmrpflash worked!!! Switching to a Static IP address and turning my Wifi off did the trick!!
Also, recommend using -vvv to double check when it works. Took me two tries to nail the timing because the router has to finish restarting for the packet transfer to begin before the command times out.
moonweasel
Dec 19, 2018Aspirant
This post was helpful in my quest, since like you mentioned, the TFTP commands listed in all the Windows unbricking guides don't work in macOS Terminal.
For me the method still does not work, because in Step 3, ping returns mostly
Request timeout for icmp_seq xx
without the
ttl=100
waymer66
Aug 18, 2020Aspirant
I have followed the instructions to the letter, as outlined in the first post:
Ran a cable from the computer directly to the first LAN port.
Opened System Preferences/Network and keyed in the following:
Configure IPv4: Manually
IP Address: 192.168.1.10
Subnet Mask: 255.255.255.0
Router: (left blank)
I opened up the terminal and commanded it to the desktop. I opened another window in the terminal and entered “ping 192.168.1.1”.
I get the message Request timeout for icmp_seq (number).
What am I doing wrong or is this proof that the router is toast? Thanks.
