kryptonix
Sep 26, 2018Guide
How to unbrick the Nighthawk R7000 using OS X and TFTP
Hi,
After spending a night on unbricking my R7000 and how I struggled to work with all the manuals out there but none of them actually worked. I thought I should share what actually worked for ...
- Sep 27, 2021
HOLY COW IT WORKED!!!
nmrpflash worked!!! Switching to a Static IP address and turning my Wifi off did the trick!!
Also, recommend using -vvv to double check when it works. Took me two tries to nail the timing because the router has to finish restarting for the packet transfer to begin before the command times out.
seethelight
Nov 24, 2020Aspirant
Hi guys, fantastic summary. It works perfectly until the very last point. When i type put _ name of the file after few second i receive the message "transfer timed out".
The shell with the ping repietely have the following lines:
Request timeout for icmp_seq 1874
Request timeout for icmp_seq 1875
Request timeout for icmp_seq 1876
64 bytes from 192.168.1.1: icmp_seq=1877 ttl=63 time=1.824 ms
64 bytes from 192.168.1.1: icmp_seq=1878 ttl=63 time=1.571 ms
64 bytes from 192.168.1.1: icmp_seq=1879 ttl=63 time=1.780 ms
Request timeout for icmp_seq 1880
Request timeout for icmp_seq 1881
Request timeout for icmp_seq 1882
Request timeout for icmp_seq 1883
ping: sendto: No route to host
Request timeout for icmp_seq 1884
ping: sendto: Host is down
Request timeout for icmp_seq 1885
Request timeout for icmp_seq 1886
Request timeout for icmp_seq 1887
anyone would be able to advise how i can get the last step done? it seems to me that the router keeps rebooting so that there is no enough time to transfer the new firmware?
