kryptonix
Sep 26, 2018Guide
How to unbrick the Nighthawk R7000 using OS X and TFTP
Hi,
After spending a night on unbricking my R7000 and how I struggled to work with all the manuals out there but none of them actually worked. I thought I should share what actually worked for ...
- Sep 27, 2021
HOLY COW IT WORKED!!!
nmrpflash worked!!! Switching to a Static IP address and turning my Wifi off did the trick!!
Also, recommend using -vvv to double check when it works. Took me two tries to nail the timing because the router has to finish restarting for the packet transfer to begin before the command times out.
seethelight
Nov 24, 2020Aspirant
Apologies for the multiple messages, diregard the previous one.
Some context first:
I have a r8000 which i understand is very similar to r8000 in terms of troubleshooting. I was trying to flash the router with Advance tomato. The firmware seemed to be correctly installed but clearly this was not the case as after the installation was completed the router got stuck in what i believe is a reboot loop. after spending pratically all night trying to resolve it I came across this post. I followed all the steps mentioned and i got until the last one where after i send the command to install the latest version of original netgear firmware i receive the message, like many others above, "request timed out".
I diligently read the advise that antinode gave to previous users and therefore see below the copy and paste from the two shells i have used to type the commands.
Shell with commands:
Last login: Tue Nov 24 01:48:43 on ttys001
diego@Dies-Air ~ % ls
Applications
Creative Cloud Files
Desktop
Documents
Downloads
Library
Movies
Music
OneDrive
Pictures
Public
iCloud Drive (Archive)
diego@Dies-Air ~ % cd desktop
diego@Dies-Air desktop % ls
Accounts.xlsx TFTP Client 2.app
DS_Store.txt TFTP Client.app
Documents Transfer_1.3.dmg
FOTO (EXPORT) Worksheet 2019:2020v1.xls
R8000-V1.0.4.62_10.1.74 nmrpflash
R8000-V1.0.4.62_10.1.74.chk nmrpflash-0.9.14-macos.zip
R8000-V1.0.4.62_10.1.74.zip tftp_client_122_intel.zip
diego@Dies-Air desktop % tftp
tftp> connect 192.168.1.1
tftp> status
Connected to 192.168.1.1.
Mode: netascii Verbose: off Tracing: off
Rexmt-interval: 5 seconds, Max-timeout: 25 seconds
tftp> binary
tftp> put R8000-V1.0.4.62_10.1.74.chk
Transfer timed out.
SHELL WITH PING
Last login: Tue Nov 24 01:54:42 on ttys001
diego@Dies-Air desktop % ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1): 56 data bytes
64 bytes from 192.168.1.1: icmp_seq=0 ttl=100 time=25.285 ms
64 bytes from 192.168.1.1: icmp_seq=1 ttl=100 time=2.573 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=100 time=2.495 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=100 time=2.499 ms
Request timeout for icmp_seq 4
Request timeout for icmp_seq 5
Request timeout for icmp_seq 6
Request timeout for icmp_seq 7
Request timeout for icmp_seq 8
Request timeout for icmp_seq 9
Request timeout for icmp_seq 10
Request timeout for icmp_seq 11
Request timeout for icmp_seq 12
Request timeout for icmp_seq 13
Request timeout for icmp_seq 14
Request timeout for icmp_seq 15
Request timeout for icmp_seq 16
Request timeout for icmp_seq 17
Request timeout for icmp_seq 18
Request timeout for icmp_seq 19
Request timeout for icmp_seq 20
Request timeout for icmp_seq 21
Request timeout for icmp_seq 22
Request timeout for icmp_seq 23
Request timeout for icmp_seq 24
Request timeout for icmp_seq 25
Request timeout for icmp_seq 26
Request timeout for icmp_seq 27
Request timeout for icmp_seq 28
Request timeout for icmp_seq 29
Request timeout for icmp_seq 30
Request timeout for icmp_seq 31
Request timeout for icmp_seq 32
Request timeout for icmp_seq 33
Request timeout for icmp_seq 34
Request timeout for icmp_seq 35
Request timeout for icmp_seq 36
ping: sendto: No route to host
Request timeout for icmp_seq 37
Request timeout for icmp_seq 38
Request timeout for icmp_seq 39
Request timeout for icmp_seq 40
Request timeout for icmp_seq 41
Request timeout for icmp_seq 42
Request timeout for icmp_seq 43
Request timeout for icmp_seq 44
Request timeout for icmp_seq 45
Request timeout for icmp_seq 46
Request timeout for icmp_seq 47
Request timeout for icmp_seq 48
Request timeout for icmp_seq 49
Request timeout for icmp_seq 50
Request timeout for icmp_seq 51
64 bytes from 192.168.1.1: icmp_seq=49 ttl=100 time=3631.749 ms
64 bytes from 192.168.1.1: icmp_seq=50 ttl=100 time=2630.577 ms
64 bytes from 192.168.1.1: icmp_seq=53 ttl=100 time=2.544 ms
64 bytes from 192.168.1.1: icmp_seq=54 ttl=100 time=2.523 ms
64 bytes from 192.168.1.1: icmp_seq=55 ttl=100 time=2.076 ms
64 bytes from 192.168.1.1: icmp_seq=56 ttl=100 time=2.541 ms
Request timeout for icmp_seq 58
Request timeout for icmp_seq 59
Request timeout for icmp_seq 60
Request timeout for icmp_seq 61
Request timeout for icmp_seq 62
Request timeout for icmp_seq 63
Request timeout for icmp_seq 64
Request timeout for icmp_seq 65
Request timeout for icmp_seq 66
Request timeout for icmp_seq 67
Request timeout for icmp_seq 68
Request timeout for icmp_seq 69
Request timeout for icmp_seq 70
Request timeout for icmp_seq 71
Request timeout for icmp_seq 72
Request timeout for icmp_seq 73
Request timeout for icmp_seq 74
Request timeout for icmp_seq 75
Request timeout for icmp_seq 76
Request timeout for icmp_seq 77
Request timeout for icmp_seq 78
Request timeout for icmp_seq 79
Request timeout for icmp_seq 80
Request timeout for icmp_seq 81
Request timeout for icmp_seq 82
Request timeout for icmp_seq 83
Request timeout for icmp_seq 84
Request timeout for icmp_seq 85
Request timeout for icmp_seq 86
Request timeout for icmp_seq 87
Request timeout for icmp_seq 88
Request timeout for icmp_seq 89
Request timeout for icmp_seq 90
Request timeout for icmp_seq 91
Request timeout for icmp_seq 92
Request timeout for icmp_seq 93
Request timeout for icmp_seq 94
Request timeout for icmp_seq 95
Request timeout for icmp_seq 96
ping: sendto: Host is down
Request timeout for icmp_seq 97
Request timeout for icmp_seq 98
Request timeout for icmp_seq 99
Request timeout for icmp_seq 100
Request timeout for icmp_seq 101
Request timeout for icmp_seq 102
Request timeout for icmp_seq 103
Request timeout for icmp_seq 104
64 bytes from 192.168.1.1: icmp_seq=105 ttl=100 time=5.389 ms
64 bytes from 192.168.1.1: icmp_seq=106 ttl=100 time=2.545 ms
64 bytes from 192.168.1.1: icmp_seq=107 ttl=100 time=2.514 ms
64 bytes from 192.168.1.1: icmp_seq=108 ttl=100 time=2.599 ms
Request timeout for icmp_seq 109
it seems to me that there is no enough time to install the firmare as the router keeps re-booting?
techtherapy kryptonix antinode any guidance much appreciated -
kryptonix
Nov 24, 2020Guide
Quick reply - when you LS your desktop, the file is not listed. Unpack the zip file with the chk, put the chk on the desktop then try again;)
- antinodeNov 24, 2020Guru
> the router keeps re-booting?That can be a problem. I'd try fiddling with power-on and Reset
timing, hoping to get lucky.If you can't find a time window when it works, then you might need to
bring out the big guns, like opening the box and attaching a serial port
adapter, and using that to interrupt whatever it's doing. A Web search
for terms like, say:
netgear serial port
should find more information.
> Quick reply - when you LS your desktop, the file is not listed. [...]Try a slower reply? I see it there. Did the program complain about
"No such file or directory"? "ls" and "ls -1" are different. (So is
"LS".) File names which include spaces can cause confusion, too.
