kryptonix
Sep 26, 2018Guide
How to unbrick the Nighthawk R7000 using OS X and TFTP
Hi,
After spending a night on unbricking my R7000 and how I struggled to work with all the manuals out there but none of them actually worked. I thought I should share what actually worked for ...
- Sep 27, 2021
HOLY COW IT WORKED!!!
nmrpflash worked!!! Switching to a Static IP address and turning my Wifi off did the trick!!
Also, recommend using -vvv to double check when it works. Took me two tries to nail the timing because the router has to finish restarting for the packet transfer to begin before the command times out.
itsmevgupta
Sep 26, 2021Aspirant
Did you find any resolution to this? I am running into the same issue and my router is in a constant restart loop.
brunomartorella
Sep 26, 2021Tutor
Did not. At this point I’m just gonna toss it in the trash can
- seethelightSep 26, 2021AspirantThat’s exactly what I did. Tossed it out
- itsmevguptaSep 26, 2021Aspirant
I finally managed to fix mine. Used the other method nmpr flash method.
https://github.com/jclehner/nmrpflash- brunomartorellaSep 27, 2021Tutor
Super silly question coming from someone who is not well versed with terminal (or any coding)... how do I actually install nmrpflash? I downloaded it for Mac OS, navigated to the directory where it's at in Terminal, but then typing "nmrpflash -L" gives me nothing...
-->xxxxxx:~/Downloads$ nmrpflash -L
-bash: nmrpflash: command not found
