Barryt100's avatar
Barryt100
HP Microserver not connecting to new router AC1900
I have a HP microserver.  t connects it through my router to my computer.  I have recently bought a AC1900 but I cannot access my microserver.  How can I connect my microserver to my computer through...
  • antinode's avatar
    May 24, 2018
       Does it have a model number?  Is it running some operating system?
    > I have recently bought a AC1900 [...]
       "AC1900" is a speed, not a model number.  Ever helpful, Netgear
    product packaging emphasizes speeds like "ACxxxx", but that's not the
    model identifier.  Look at the product label.
    >  Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
       Is that accurate?  Firmware version?
    > [...] but I cannot access my microserver.
       Whan you do what, exactly?  "cannot" is not a useful problem
    description.  It does not say what you did.  It does not say what
    happened when you did it.  As usual, showing actual actions with their
    actual results (error messages, LED indicators, ...) can be more helpful
    than vague descriptions or interpretations.  "access" is no better.
    > [...] How can I connect my microserver to my computer through my
    > router?
       Ethernet cables?  What, exactly, does "connect" mean to you?  What,
    exactly, would you like to do?
