Barryt100
May 23, 2018Aspirant
HP Microserver not connecting to new router AC1900
I have a HP microserver. t connects it through my router to my computer. I have recently bought a AC1900 but I cannot access my microserver. How can I connect my microserver to my computer through...
- May 24, 2018
Does it have a model number? Is it running some operating system?
> I have recently bought a AC1900 [...]
"AC1900" is a speed, not a model number. Ever helpful, Netgear
product packaging emphasizes speeds like "ACxxxx", but that's not the
model identifier. Look at the product label.
> Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Is that accurate? Firmware version?
> [...] but I cannot access my microserver.
Whan you do what, exactly? "cannot" is not a useful problem
description. It does not say what you did. It does not say what
happened when you did it. As usual, showing actual actions with their
actual results (error messages, LED indicators, ...) can be more helpful
than vague descriptions or interpretations. "access" is no better.
> [...] How can I connect my microserver to my computer through my
> router?
Ethernet cables? What, exactly, does "connect" mean to you? What,
exactly, would you like to do?
IrvSp
May 24, 2018Master
That SERVER has an Ethernet Port which I assume you connected to the router.
Now all you need do is SHARE that Server, just like any other PC. So what PC do you have and what OS is it running? Windows 10? You'll need to enable SMB1 to see a share. Probably need to set up the server to allow access by devices on your LAN as well. If you want External access, that has to be set up as well.
Please explain what you've tried and what isn't working? Do you see the server on the router as a connected device on the LAN map?
More info is really needed here to assist you.
Barryt100
May 24, 2018Aspirant
My operating system is Windows 7. I had an old router which was connected to my microserver. Everything was working fine. I upgraded my router to a AC1900 R7000 and now the router will not connect to my microserver. When I go to my router I cannot see my microserver as being listed as a device. Can you help?
