Barryt100
May 23, 2018Aspirant
HP Microserver not connecting to new router AC1900
I have a HP microserver. t connects it through my router to my computer. I have recently bought a AC1900 but I cannot access my microserver. How can I connect my microserver to my computer through...
- May 24, 2018
Does it have a model number? Is it running some operating system?
> I have recently bought a AC1900 [...]
"AC1900" is a speed, not a model number. Ever helpful, Netgear
product packaging emphasizes speeds like "ACxxxx", but that's not the
model identifier. Look at the product label.
> Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Is that accurate? Firmware version?
> [...] but I cannot access my microserver.
Whan you do what, exactly? "cannot" is not a useful problem
description. It does not say what you did. It does not say what
happened when you did it. As usual, showing actual actions with their
actual results (error messages, LED indicators, ...) can be more helpful
than vague descriptions or interpretations. "access" is no better.
> [...] How can I connect my microserver to my computer through my
> router?
Ethernet cables? What, exactly, does "connect" mean to you? What,
exactly, would you like to do?
IrvSp
May 24, 2018Master
More questions, what other router did you have?. Are you replacing it or trying to add the R7000?
Barryt100
May 24, 2018Aspirant
My old router stopped working so I replaced it with a AC1900 R7000. My microserver worked with the old router but doesn't work with the AC1900 R7000
- antinodeMay 24, 2018Guru
> My operating system is Windows 7. [...]
What's the OS on your (unspecified) "my microserver"?
> [...] I had an old router which was connected to my microserver.
> Everything was working fine.
What was the IP address of your (unspecified) "my microserver" then?
If you configured your (unspecified) "my microserver" with a static IP
address compatible with your (unspecified) "an old router", and it's now
incompatible with your R7000, then that could explain much.
> [...] When I go to my router I cannot see my microserver as being
> listed as a device. [...]
When you do _what_? Are you looking at a "BASIC > Attached Devices"
report, or what?
> [...] I upgraded my router to a AC1900 R7000 and now the router will
> not connect to my microserver. [...]
With my weak psychic powers, I have no idea how your (unspecified)
"my microserver" is connected to the R7000, if the LED indicators on the
R7000 and/or your (unspecified) "my microserver" indicate a good
physical link, or how you configured the network interface on your
(unspecified) "my microserver".
> [...] Can you help?
Can you provide some basic information?- IrvSpMay 25, 2018Master
antinode, did something go wrong with the forum s/w? You have 3 identical answers at 3 different times(1 marked as Solution so maybe the s/w duplicates it)?
Barryt100, did you mark one of his an answer, yet I don't see one? What is the 'spoiler' that shows nothing?
Confused here?
- Barryt100May 25, 2018Aspirant
I am confused. I was just replying to the questions asked. I still cannot connect to my microserver. Can anyone help please. I will repeat myself again. I had a WNDR3700v4 router which was connected to my microserver. everything was working fine. Then my router stopped working so I purchased a AC1900 R7000 and now it will not connect to my HP Microserver. I assume that it is the router that is the problem. Again can anyone please help me
