Barryt100
May 24, 2018Aspirant
HP Microserver not connecting to new router AC1900
I have a HP microserver. t connects it through my router to my computer. I have recently bought a AC1900 but I cannot access my microserver. How can I connect my microserver to my computer through...
- May 24, 2018
Does it have a model number? Is it running some operating system?
> I have recently bought a AC1900 [...]
"AC1900" is a speed, not a model number. Ever helpful, Netgear
product packaging emphasizes speeds like "ACxxxx", but that's not the
model identifier. Look at the product label.
> Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Is that accurate? Firmware version?
> [...] but I cannot access my microserver.
Whan you do what, exactly? "cannot" is not a useful problem
description. It does not say what you did. It does not say what
happened when you did it. As usual, showing actual actions with their
actual results (error messages, LED indicators, ...) can be more helpful
than vague descriptions or interpretations. "access" is no better.
> [...] How can I connect my microserver to my computer through my
> router?
Ethernet cables? What, exactly, does "connect" mean to you? What,
exactly, would you like to do?
William10a
May 26, 2018Master
True the server would have to had its own ip address for it to work in the past on the network could connect the server to a computer and do a ipconfig to see the servers address. Then set the address up as a private address so the router could see it.
IrvSp
May 26, 2018Master
Yes, but if the old router had a different Gateway IP Address the Server used and IP Address in that net it isn't that easy. The easy way would be to change the Router's IP Address to be one that the Server requires. This assumes the OP had NO way to access the Server unless it was on a LAN?
The default IP Address for the WNDR3700 is 192.168.1.1 which should be the same for the R7000. However the original router could have a different IP Address because if it did, it should not work out of the box without changing the R7000 to a matching IP Address.
Of course there could be other reason the OP 'forgot' about? He could have a reserved IP Address for the Server, but didn't set up the R7000 to do that? In that case he's trying to go to 192.168.1.x but the server isn't there. If on Windows, a NET VIEW might show where it was?
A lot of useful info has NOT been provided yet, so all we can do is 'guess'?
- Barryt100May 27, 2018Aspirant
OK, I am a bit confused. My WNDR3700x4 had an ip address of 192.168.15.1 and my AX1900 R7000 has an ip address of 192.168.1.1 so do you think I should change the AC1900 R7000 to 192.168.15.1? Will that allow the microserver to talk to my Computer? If yes where do I go to change my Ip address?
Also would my microserer have an ip addrees entered into its programming so it only sees 192.168.15.1?
- IrvSpMay 27, 2018Master
YES if it REALLY was at that IP Address. That is QUITE unusual for a router that is connected to a modem directly? Was the old router set to AP mode possibly?
Anyway, you have 2 different SUBNETS. They can't talk to each other.
Connect to the router with a Browser. On the top ADVANCED tab, on the side tab SETUP, LAN SETUP, you'll see the IP Address of 192.168.1.1, change that. All devices attached will lose connection probably. They ALL will need to be rebooted after the router finishes rebooting. If any other device is no set to have an IP Address in the 192.168.1.x range it too will need to be changed to match the new address.
MAKE SURE you have a WIRED PC to do this too. Just in case something goes wrong, it will be able to connect to the router and return the IP Address to 192.168.1.1 in case this shouldn't work. It might not IF you have the router in AP mode.
- antinodeMay 27, 2018Guru
That would make some sense.
It might. That would depend on how your "the microserver" is
configured.
How should the non-psychics in your audience know?
> What's the OS on your (unspecified) "my microserver"?
Still waiting for some useful information.
I don't know what that means, but it sounds like nonsense. - Barryt100May 28, 2018Aspirant
Thank you - Thank you - Thank you. I went into the setup for my router and changed the ip address to 192.168.15.1 (thank you for the directions) and guess what - everything is working fine. My computer is talking to my micrserver and I can now access my data. again thank you - thank you -thank you.
- Barryt100Jun 03, 2018Aspirant
Hi Guys sorry I'm back again but I am having problems with my router. Since I changed to 192.168.15.1 I cannot log into genie. It asks for a passwork in 192.168.1.1 but when I type in "password" it rejects it then asks me for a 192.168.15.1 password. when I type in "password" it rejects that as well. I have tried every password that I know but it rejects them all. After a period of time I get a screen asking for a router serial number. when I put that in I get another screen asking me to answer some questions. when I answer the questions I hit "enter'' but nothing happens. It just freezes. I have gone through the same process a number of times but it freezes when I try to pass the question stage. So I cannot get into genie. The reason I want to get into Genie is because my router is running terribly slowly. I ran OOkla speed test and got a download speed of .12 and an upload speed of .12 Can anyone help please?
- IrvSpJun 03, 2018Master
What EXACTLY is your NETWORK TOPOLOGY at this point?
- What is the modem modem and number and it owned by your or the ISP (even if rented from them)?
- What does the modem connect to?
- Router is R7000 correct? Is that connected to the modem and which PORT is the cable to the modem connected via?
- What is the color of ALL the modem lights?
- On a WINDOWS computer, press the Windows Key and R at the SAME TIME:
- ENTER IPCONFIG /ALL
- What is the GATEWAY IP ADDRESS?
- ENTER NET VIEW and COPY and PASTE the results into the REPLY here.
- Can you REACH the Server?
- IF SO, can you see its settings?
- What is its IP Address?
- ENTER NBTSTAT -A 192.168.15.1 and copy and paste the output in the reply.
- ENTER NBTSTAT -A 192.168.1.1 and copy and paste the output in the reply.
- What BROWSER are you using?
- Can you try ANOTHER BROWSER?
- Did you enter ROUTERLOGIN.NET or 192.168.15.1 into the URL Location of the browser?
- What IS the IP Address of the Server and is STATIC or RESERVED?
- If you DISCONNECT the Server from the LAN, can you log into the server?
Without ALL the above info my best guess would be to RESET the router completely and start over with the settings. However, if you CAN get to the Server settings, I'd reset that to be on the 192.168.1.1 LAN before doing the RESET. It is really hard to tell with very limited information and no experience with that server what is going on? Somehow I think you've got some misconfiguration between the server and LAN, possibly a setting within the server?
- myerswJun 03, 2018Master
Have never used the genie, but would guess it has a configuration option for router IP address. Always find "tools" like it more grief then good for my liking.
What happens if you point a browser to the router's IP address? That is how I do all my router management.
The Browser DOES open up 'Genie'... that is what it is called. NG has also removed the Genie app for tablets and phones. Now NIGHTHAWK is used (a lesser version of Genie though it seems).
At least that is what I assumed he has done, used the browser.
Got ya. Have configured so many different routers, Netgear, Linksys, Asus over more then 10 years, dating back to the Linksys WRT54G when they were new and running DD-WRT. ;) So I do not bother to read the manuals most of the time if I can access via the router IP address which I find the first time via a Windows ipconfig so may not be up on nominclature. Can usually figure out things without the manual, but to refer to it at times. Been involved with computers and networks since 1961 working for IBM. Last job was support staff for a nation wide network of 150 locations.
IrvSp wrote:
myersw, since '64 at IBM, always in development, even OS/2 :smileyhappy: Now retired...
Started with IBM as a "customer Engineer". Never really understood the name as you were more of a tech working on mainframes and early on card equipment. Then went to marketing as a SE retired as a Advisory SE with specialty in networking. Remember OS2 well.
