Thunder99's avatar
Thunder99
HTTP 401
error HTTP 401,  how to fix this ?
  • Thunder99's avatar
    Thunder99
    Apr 09, 2022
    error happened after trying to reset password here (hitting CANCEL for the password to reset it) :
    www.routerlogin.net
    But not an issue anymore; because I have figured out the old password.
    Thanks Anyway.
  • plemans's avatar
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.For what?
    You gave us nothing other than an error.
    Not the equipment you're using, what you were doing to  cause, or whats you're actually trying to do.
  • michaelkenward's avatar
    michaelkenward
    Start by explaining what you are doing and what happens.
    Oh, and what Netgear devices are you using?
      Thunder99
      www.routerlogin.net
      Thanks Anyway.
