mypotato's avatar
mypotato
I am unable to download the larger files using ReadyCloud. Please Help Me!
I have a Nighhawk R7000 router.  After I first set up my ReadyCloud I was able to download some of the larger files stored on it.  Recently I found out it is limiting them to a very small size.  I would like to be able to use it as it worked in the beginning.  I am not sure if something changed on the last firmware update or why it is not working now, but would really appreciate someone's help.
Thanks So Much!!!
  • Hi mypotato,
    Please provide an update or any feedback when using the beta firmware. Your information will be helpful to us.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi mypotato,
    What is the firmware version of the router?
      • JamesGL's avatar
        JamesGL
        Hi mypotato,
        This firmware has been pulled out from support site. I would suggest you revert back to v1.0.4.30 or use the beta firmware v1.0.6.40(here). Reset the manually reconfigure after changing the firmware.
  • JennC's avatar
    JennC
    Hello mypotato,
    Welcome to the community!
    I'm moving your post to the right board.
    Regarsd,
