SoCalGirl
Apr 15, 2026Follower
I can't get it to setup via the app
I also am trying to use this router (I had it in storage for a minute) again, and I can't get it to setup via the app, and I can't login via the browser site http://www.routerlogin.net. please help. ...
CrimpOn
Apr 15, 2026Guru - Experienced User
What happens if you connect the smartphone running the Nighthawk app to the router WiFi network (as printed on the label) and simply open the app?
Do you have a device with a larger screen that can be connected to the router with Ethernet or WiFi?
