fabitorychter
Sep 26, 2025Aspirant
I can't get past the "Updating DST Adapter Information ..." spinning wheel
Have you found a solution? The same thing is happening to me after a factory reset... I can't get past the "Updating DST Adapter Information ..." spinning wheel. It was working well before the...
Sep 26, 2025Guru - Experienced User
You will want to check out page 25 onward: https://www.downloads.netgear.com/files/GDC/R7300DST/R7300DST_UM_06Oct2015.pdf
- fabitorychterSep 26, 2025Aspirant
I've just read. It doesn't seem to help.
The router can't connect to the update server (updates1.netgear.com) and Genie gets the "connection broken icon" below. If I reload, I go either to the "Updating DST Adapter Information ..." spinning wheel or a broken link page.
My firewall is off.
I am also trying with a wired connection but it doesn't seem to work.
