fabitorychter
Sep 26, 2025Aspirant
I can't get past the "Updating DST Adapter Information ..." spinning wheel
Have you found a solution? The same thing is happening to me after a factory reset... I can't get past the "Updating DST Adapter Information ..." spinning wheel. It was working well before the...
Sep 26, 2025Guru - Experienced User
- Don't use the genie. Log in through the browser for setup. Factory reset the router and set it up through the browser.
- Manually update it. Its an old device. I'd get the firmware from here: https://www.netgear.com/support/product/r7300dst/ and update it yourself.
- photos of where its failing help.
