Neenas's avatar
Neenas
Tutor
Aug 26, 2017
I'm looking for the privacy separator on nighthawk 1750 model R6700
Can't print but printer is on the network
  • Neenas's avatar
    Neenas
    Aug 27, 2017
    Finally figured it out.  On each device where the net gear genie is installed the access control must be "on".
  • michaelkenward's avatar
    michaelkenward
    Print from what?
    You usually have to set up a printer on the PC, or whatever it is, before it will send anything to the printer.
    We know nothing about your printer. The make? Model? How it is connected (wifi? LAN? USB?)
    Tell us more and maybe someone can help.
    PS What is a "privacy separator"?
    • William10a's avatar
      William10a
      Master
      michaelkenward wrote:
      Print from what?
      True normally the printer is only conected to a network by wifi or a lan cable to the network and you have too install a driver for the printer on your devicesto use them with the printer for most modern printers.
      Not sure privacy separator is either.
      Are you trying too make two different networks on one router?
      • Neenas's avatar
        Neenas
        Tutor
        I have a Brother DCP-2540DW. I believe the printer is connected to the network per the genie. I was able to print from my iPhone 7 and my iPad but now I'm getting a diagnostic stating no supported devices found -check that the Wi-Fi access point/routers "privacy separator" is disabled.
