Shinelikethunde
Jan 23, 2026Tutor
I'm using a Netgear R7000
I'm using a Netgear R7000. Genie v2.4.62 will not let me change the iPhone name that I previously entered from the web administration interface, nor does it show the name that was entered on the iPho...
Jan 26, 2026Guru - Experienced User
Genie app is an old app that isn't supported anymore.
Try using the Nighthawk app with the R7000.
Check with Apple on how to rename there devices.
