Retired_Member
Jan 01, 2016Impressive R7000 Firmware HERE
ftp://download.netgear.com.cn:8084/R7000/R7000-V1.0.5.52_1.1.81.chk so thats the beta firmware, I've just downloaded it and so far its pretty impressive... I nearly got 60Mbs on an laptop that couldn't get past 45Mbs on any other firmware, thats was on 2G, auto channel. And 5G is also faster (AC Note 3). Port forwarding is also better and everyhting is fast!!! just download it, and see what you think...
other good things about it are here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-V1-0-5-52-1-1-81-chk/td-p/1024843
NETGEAR WHAT EVER YOU HAVE DONE TO THIS DO TO YOUR OTHER FIRMWARE... :smileyvery-happy: :smileylol:
Did you do a reset right after you've installed 6.28? Because my download speed wasn't good either, I then wanted to try a previous firmware, did a reset, but just before I installed 4.28, so right after the reset, I did a download test and it was as fast as before, >600Mb (and yesterday >700): [URL=http://www.speedtest.net/my-result/4983956305][IMG]http://www.speedtest.net/result/4983956305.png[/IMG][/URL]
- Retired_Member
You would think they NETGEAR would had jumped in on that thread BUT instead they rush another POS according to some. I've been on the 1.0.6.28 longer the other and still kicking the tires.
If I could get the blue update banner to go away I'd switch back to it.
- LeKeiserLuminary
Hello,
Did you have to do a full reset before/after? What about the backups? Useful or not?
Thanx :)
- Retired_Member
before and after :)
- LeKeiserLuminary
Question again: does the ReadyShare printer works WITH the access control settings on? Doesn't work with the previous firmware from Netgear, so...
- suku_patel_22AspirantMy download speed was **bleep** on 6.28 version. Back to 5.48 and happy again. Guess we need to take in alternate builds :D
- LeKeiserLuminary
- suku_patel_22AspirantI guess I did, not so sure now. After trying out AdvancedTomato and DDWRT, I am back to 1.05.48 and it's been very stable.
I will wait for a while and then upgrade.
