joet327's avatar
joet327
install R7000 router w/o a smartphone
Is there a way of installing a nighthawk router without using a smart phone.  Yes!  I'm the last smartphone hold out:)
  • plemans's avatar
    Yes you can.
    You use the browser. It'll pop up a screen that recommends using the app but if you scroll down, theres a link that says something like I don't have a compatible smart phone and you can click that to setup using the browser.
  • michaelkenward's avatar
    michaelkenward
    You can also use a wired connection into the router from a PC to get it up and running.
    • joet327's avatar
      joet327
      I don't have port to connect it to.
        michaelkenward
        In which case, if the phone app fails you, do as plemans suggests and use a browser on your phone.
        The process is the same as a wired connection after you have connected the phone to the router's wifi. This is described in the manual. Read the section:
        Use a Web Browser to Access the Router
        Unfortunately, the current Installation Guide insists that the app is the only option. The original version was much more useful.
