SuzyQ77
Jul 07, 2026Aspirant
Intermittent Internet DoS attacks (RST & Fraggle)
I have a Nighthawk RAX50v2 router that I set up maybe 3 or 4 months ago. Due to a neighbor having fiber installed 2 doors down, my cable line with Spectrum was completely cut in mid-June. The cable...
- Jul 07, 2026
Those tend to be false positives and nothing to worry about. You can go into the logs and disable the logging of them if they bother you.
If you're having wired drops, it tends to not be the router and more likely the line. the problem with spectrum is they locked down their modems so you can't check the logs/line connections on the modems anymore. Easy check? Take the router out of the loop for a period. Just directly connect a pc to the modem and use it. See if it drops or stays stable. Its not definitive if it happens rarely but if its happening, they can't blame the router.
SuzyQ77
Thank you - I looked up the IP addresses and realized all the fraggle attacks were Spectrum-related. I'll give your suggestion a try. Thanks again!
