Steve-HPC
May 11, 2025Tutor
Internet connection Interruption
Over the past couple of weeks I have noticed internet connection interruptions. I'm trying to track down the source of the interruptions. I started with the Netgear Nighthawk R7000 logs and foun...
May 13, 2025Guru - Experienced User
Been a long time since I seen that old of a firmware. Its about 25 versions behind for the R7000.
Which fiber don't?
So its only happened 2x? Total?
But you're not sure if it was long or short?
And its fixed with resetting the computers NIC?
