Ger1234
Sep 27, 2016Aspirant
Internet drops R7000
Hello, I'm experiecing Internet Drops on my R7000 router. The router is placed behind a Ubee (Ziggo) modem in bridged mode and the problem occurs on LAN and Wifi connections. I read on other...
- Jan 07, 2017
Didn't have time to run wifi speedtests, but everything is still pretty stable (at least not noticeable) with the last settings I made.
I wil close this topic, with the accepted solution of disabling QoS.
JamesGL
Sep 29, 2016NETGEAR Employee Retired
Hi Ger1234,
1. What is the firmware version of the router? If it is not on the latest, try to update the firmware.
2. How often the dropping of connection happens? What's is the interval?
JamesGL
Community Team
Ger1234
Oct 01, 2016Aspirant
Hi James,
1. My firmware version should be the last one V1.0.7.2_1.1.93
2. I use this tool to check the speed https://www.ziggo.nl/speedtest?ecmp=sbr-307-13908&gclid=CLPSsKbfnc8CFUUq0wodVkQJMA&gclsrc=aw.ds&dclid=CKeSwKbfnc8CFdMD0wodpnIJ0w
Normally this should give a straight line on 150Mbit, now it shows anaverage around the 100Mbit. The interval is random
I'm not sure, but maybe it started to be unstable since the last firmware (or maintenance on Ziggo side??)
Gerhard
