Ger1234
Sep 27, 2016Aspirant
Internet drops R7000
Hello, I'm experiecing Internet Drops on my R7000 router. The router is placed behind a Ubee (Ziggo) modem in bridged mode and the problem occurs on LAN and Wifi connections. I read on other...
- Jan 07, 2017
Didn't have time to run wifi speedtests, but everything is still pretty stable (at least not noticeable) with the last settings I made.
I wil close this topic, with the accepted solution of disabling QoS.
Pac-Man
Nov 27, 2016Tutor
This is a 2.4G result i get using firmware 1.0.3.24 .My 5G result will be around 218.00 Mbps.
My ISP provides me with 200Mbps .The latest firmware wont get near these results for me .
- Ger1234Dec 06, 2016Aspirant
Hi Pacman,
Thanks for your feedback.
I fixed the problems I had with the Ookla speedtest and my VPN connection to the Office (the VPN connection was extremely slow) both wired and working on the latest firmware.
Because I was having drops on Spotify using my wifi speakers I enabled QoS. With this option enabled and giving the wifi speaker the highest prio the drops were gone, but I was having problems with Ookla speedtest and my VPN to the office.
I disabled QoS and at the moment I dont have any problems with spotify on the latest firmware.
Will try to run some speed test using wifi and the latest firmware to see if I have drops.
At the moment very happy to be able to work with a fast VPN connection and no drops streaming spotify.
Gerhard
- Ger1234Jan 07, 2017Aspirant
