Aashrex
Jan 07, 2026Aspirant
Internet goes away in 2.4Ghz a few times a day
I have a AC1750 wifi router and the internet goes away for about 2 minutes in 2.4Ghz band. Happens 2-3 times a day. I bought this router in 2021. Please suggest how to troubleshoot.
Jan 08, 2026Guru - Experienced User
Aashrex wrote:I have a AC1750 wifi router
AC1750 is a speed rating - can you give us the actual model?
Do you know for certain that the drop is only in the 2.4 ghz band? Or is it possible that it effects 5 ghz, and maybe even ethernet?
- AashrexJan 19, 2026Aspirant
Sorry, the device is R6350. It is only happening for the 2.4Ghz band.
I have switched the bands to check if it was an internet issue. But 5Ghz was working fine. Problem only with 2.4Ghz
