rags1's avatar
rags1
Internet LED
Router LED blinking amber. Wireless is  dropping throughout house even on computer in same room as router. Hooking modem to router by ethernet gives excellent download speed but doing the same from the router will not connect. have restarted both modem and router following recommended instructions. Have reset router to factory default. No changes. Received notice of firmware update but trying to do it throught routerlogin, it responds that there is no update. Firmware Version is
V1.4.1.50_1.3.10.  Router is 8 months old.
Any help would be appreciated!
  • Correction. Hooking modem to computer through ethernet gives high download speed but adding the router between modem and computer, it will not connect. Wirelessly the LED blinking amber.
  • Can you tell us what model number of router you have? Also which LED is blinking on your router?
